compile the -libxml2 and libcurl for vmware monitoring
  • chvgms
    • May 2020
    • 12
    how do i compile the -libxml2 and libcurl for vmware monitoring? i have very limited knowledge in linux, hence this question. PFB output and guide me.
    For virtual machine monitoring to work, Zabbix should be compiled with the --with-libxml2 and --with-libcurl compilation options.
    [root@appliance /]# ldd /usr/sbin/zabbix_server | egrep 'libxml2|libcurl'
    libxml2.so.2 => /lib64/libxml2.so.2 (0x00007f13d1aa8000)
    libcurl.so.4 => /lib64/libcurl.so.4 (0x00007f13d03a3000)
  • tim.mooney
    • Dec 2012
    • 1432
    For someone with limited knowledge in Linux, the easiest route is generally to use the pre-built packages, assuming there are some for your platform.
    What Linux distribution and version are you using?
    • chvgms
      • May 2020
      • 12
      i am doing a poc of zabbix 5.0 appliance and want tot monitor ESXi. as per the instructions "Zabbix should be compiled with the --with-libxml2 and --with-libcurl compilation options". seems this need to run from the zabbix installation folder or location. Not sure how to do, any help in this regard will be helpful.
      • Atsushi
        • Aug 2013
        • 2028
        If you are using an official appliance, the option to monitor VMware should have been compiled with it enabled. Make sure that the value of StartVMwareCollectors in the settings file is 1 or more.
        • chvgms
          • May 2020
          • 12
          thx for the detals. i have edited the zabbix-server.conf file and uncommented StartVMwareCollectors, restarted the service and could see all guest VM's running on ESXi.
          • towerx
            • Jan 2021
            • 14
            hi may i ask how you did it. i am struggling for days thanks in advance
            • Jinaraju15
              Jinaraju15 commented
              Try adding the below in /etc/zabbix/zabbix_server.conf (replace with lib actual paths)
              LoadModulePath=/usr/lib64/libxml2.so.2
              LoadModulePath=/usr/lib64/libcurl.so.4
          • rohithmurthy
            • Jan 2020
            Hi Geeks,
            I have RHEL 8 having libcurl and libxml2 , i am struggling for few days let me know where i am missing it.
            libcurl.so.4 => /lib64/libcurl.so.4 (0x00007f2cb5db6000)
            libxml2.so.2 => /lib64/libxml2.so.2 (0x00007f2cb52b1000)
            StartVMwareCollectors = 1
            passed credentials for service a/c and URL as well.
            I am getting error :
            Received response has no valid XML data.
            Please let me know what did i missed in vmware configuration.
            Rohith
